I’m having trouble with my first Pixhawk build. I’m able to install firmware, but beyond that I’ve been unable to maintain connection or calibrate the pixhawk. I’ve been trying for a few hours each night this week but no luck (see my post in the pixhawk hardware forum). At first I was able to connect to MP for a couple minutes at a time. I’ve tried reinstalling drivers, swapping Micro SD cards, Powered USB port, going into terminal, setup, erasing EEPROM, and reinstalling firmware, installing beta firmware, reinstalling normal firmware, but no luck.
This evening, I tried to start from scratch on a new build but was unsuccessful.
I’m using a Powered USB port and 8GB Class 10 micro SD card since I didn’t have luck with the old SD card and read there may have been problems with it. For the following steps I was NOT using a LiPo and the ground station 3DR telemetry was unplugged.
I followed the First Time Setup here:
copter.ardupilot.com/wiki/initial-setup/
Here are the steps I tried this evening:
- I Installed Mission Planner 1.2.93 build 1.1.5131.36508 on my laptop running Windows 7. At the end of the installation, 3 drivers were installed.
- Ran the Setup Wizard
- Selected Quad and Plugged in Pixhawk using the powered USB hub. Pixhawk has everything installed (Motors, ESCs, External GPS/Compass, 3DR Telemetry (base station is not connected), Buzzer, Button, X8R RX module w/ Taranis).
- The Pixhawk driver automatically installed “PX4 FMU (COM7)”.
- Unplugged the USB and plugged it back in. It tried to connect to the pixhawk but encountered an error “Error uploading Firmware”.
- The pixhawk status Lights show:
- Main Light: Flashing Yellow.
- FMU: PWR: Solid Yellow, B/E: Flashing Red.
- IO: PWR: Solid Yellow, B/E: Solid Red, ACT: Blinking Blue
- Power cycled board and tried again. The current firmware is already loaded. I received the following message. “No Need to upload. Already on the board”.
- FMU: PWR: Solid Yellow, B/E: off.
- IO: PWR: Solid Yellow, B/E: Flashing Red, ACT: Blinking Blue
- After pushing OK, the wizard tried to connect but timed out with the following message “No Heartbeat Packets Received”. At this point I closed the wizard.
- I attempted to load AdruCopter V3.1.1 firmware via the “Install Firmware” tab. “No Need to upload. Already on the board”
- Next, I Installed ArduPlane V2.78b software in an attempt to re-write the firmware. After power cycling the board, the pixhawk played the “firmware updated successfully tone” followed by two long beeps, “Startup Failed”. Power cycled the board and heard “Startup Successful” followed by “Startup Failed” sounds.
- Next I tried reloaded ArduCopter V3.1.1. ERROR: Failed to read OTP.
- Tried a second time. This time it worked and played the “Firmware Update Successful” sound. Next, I power cycled the board and heard the “Startup Successful” sound.
- Main Light: Solid Yellow
- Pushed the “Connect” Button (COM7, Baud Rate: 115200). The connection tined out. “Timeout waiting for autoscan/no mavlink device connected.” Tried a second time “No Heartbeat Packets Received”.
- Attempted to Open up terminal window. The terminal told me to reboot the pixhawk. Once I did, Windows reported a driver was trying to install. At this point I received the “Device driver software was not successfully installed”.
- Pushed the reset button on the side of the device. Same light status as step #6, except a flashing yellow light.
Help! What should I do next?
