I recently took my copter for a flight. I was able to takeoff smoothly but it hovers to the right and backwards. It was hard to fly back the drone since I had to go all the way to the left to bring it stable. There is no PID control implemented and my trimming is set to default.
I have attached my bin file as well so that you guys can have a better understanding.
I will check that and let you know right away. I auto analyzed my log and this is the output:
Log File C:\Users\Admin\AppData\Local\Temp\tmpA7EB.tmp.log
Size (kb) 2894.466796875
No of lines 35119
Duration 0:05:12
Vehicletype ArduCopter
Firmware Version V3.6.11
Firmware Hash f0d59294
Hardware Type
Free Mem 0
Skipped Lines 0
Test: Brownout = GOOD -
Test: Compass = FAIL - Large change in mag_field (54.22%)
Max mag field length (635.04) > recommended (550.00)
Test: Dupe Log Data = GOOD -
Test: Empty = GOOD -
Test: Event/Failsafe = FAIL - ERR found: CRASH
Test: GPS = GOOD -
Test: IMU Mismatch = GOOD - (Mismatch: 0.47, WARN: 0.75, FAIL: 1.50)
Test: Motor Balance = GOOD - Motor channel averages = [1382, 1454, 1419, 1384]
Average motor output = 1409
Difference between min and max motor averages = 72
Test: NaNs = FAIL - Found NaN in CTUN.TAlt
Found NaN in CTUN.DSAlt
Test: OpticalFlow = FAIL - FAIL: no optical flow data
Test: Parameters = FAIL - ‘THR_MIN’ not found
Test: PM = GOOD -
Test: Pitch/Roll = UNKNOWN - ‘BarAlt’
Test: Thrust = GOOD -
Test: VCC = UNKNOWN - No CURR log data
It says “Compass = FAIL - Large change in mag_field (54.22%)
Max mag field length (635.04) > recommended (550.00)”. How do I resolve this?
Yes, it was actually the trimming issue on my transmitter. But my log says “Compass = FAIL - Large change in mag_field (54.22%)
