Does not work the HoTT telemetry support?
pixhawk.org/peripherals/telemetry/hott
I tried to reproduce this, but I get the following error:
nsh: hott_telemetry: command not found
[code] nsh> reboot
[boot] Initialized SPI port 1 (SENSORS)
[boot] Initialized SPI port 2 (RAMTRON FRAM)
[boot] Initialized SPI port 4
[boot] Initialized SDIO
[rgbled] on I2C bus 2 at 0x55 (bus: 100 KHz, max: 100 KHz)
[init] looking for microSD…
[init] card mounted at /fs/microsd
sercon: Registering CDC/ACM serial driver
sercon: Successfully registered the CDC/ACM serial driver
[init] USB interface connected
Running rc.APM
Mounting binfs
binfs mounted OK
nsh: rm: unlink failed: No such file or directory
Detected FMUv2 board
uorb started OK
Trying PX4IO board
[px4io] default PWM output device
PX4IO board OK
[PX4IO:] CRCs match
PX4IO CRC OK
MODE_4PWM
set_pwm_rate 0 50 50
[fmuservo] starting
adjusted actuator update interval to 20ms
Set FMU mode_pwm4
Starting APM sensors
[MS5611_SPI] on SPI bus 4 at 2 (11000 KHz)
ms5611: no device on bus 4
[MS5611_SPI] on SPI bus 1 at 3 (11000 KHz)
ms5611: no device on bus 1
ms5611: no device on bus 2
ms5611 started OK
init done
adc started OK
Starting FMUv2 sensors
hmc5883: no device on bus 2
hmc5883: driver start failed
No external hmc5883
hmc5883: no device on bus 1
No internal hmc5883
mpu6000: driver start failed
No MPU6000 external
[MPU6000] on SPI bus 1 at 4 (1000 KHz)
Found MPU6000
[L3GD20] on SPI bus 1 at 1 (11000 KHz)
l3gd20 started OK
[LSM303D] on SPI bus 1 at 2 (11000 KHz)
lsm303d started OK
ets_airspeed: no ETS airspeed sensor connected
meas_airspeed: no MS4525 airspeed sensor connected
ll40ls: driver start failed
trone: driver start failed
mb12xx: driver start failed
px4flow: driver start failed
started pwm_input driver
Trying PX4IO board
started mtd driver OK
reading /fs/mtd expecting 16384 bytes
readtest OK
mtd readtest OK
uavcan: Node ID 1, bitrate 1000000
uavcan: SW version vcs_commit: 0x00000000
uavcan: sensor bridge ‘gnss’ init ok
uavcan: sensor bridge ‘mag’ init ok
uavcan: sensor bridge ‘baro’ init ok
started uavcan OK
[batt_smbus] on I2C bus 2 at 0x0b (bus: 100 KHz, max: 100 KHz)
Found batt_smbus
[oreoled] on I2C bus 2 at 0x68 (bus: 100 KHz, max: 100 KHz)
oreoled started OK
rwtest /fs/mtd testing 16384 bytes
rwtest OK
mtd rwtest OK
Starting ArduPilot /dev/ttyACM0 /dev/ttyS1 /dev/ttyS2
Starting ArduPlane uartA=/dev/ttyACM0 uartC=/dev/ttyS1 uartD=/dev/ttyS2 uartE=/d ev/ttyS6
initialised /dev/ttyS3 OK 1024 512
initialised /dev/ttyS1 OK 1024 512
initialised /dev/ttyS2 OK 1024 512
initialised /dev/ttyS6 OK 1024 512
ArduPilot started OK
rc.APM finished
NuttShell (NSH)
nsh> [px4io] mixer sent
<fmuservo> MODE_4PWM
<fmuservo> set_pwm_rate 0 50 50
disabling flow control on /dev/ttyS1 _total_written=512
disabling flow control on /dev/ttyS2 _total_written=512
initialised /dev/ttyACM0 OK 4096 1024
hpwork: did not find smart battery
hpwork: did not find oreoled
nsh> hott_telemetry start
nsh>
[/code]
Andruplane 3.3.0
