When I measured the voltage across the Vcc and ground pin of the GPS port in Pixhawk, it reads 4.5V and above.
However, the data sheet of uBlox M8N GPS says supply voltage is 2.7 - 3.6V (see attached).And this GPS module has been connected to the above port for few years.
How can the GPS module survive the over-voltage without burning ?
The GPS module is separately sourced, not supplied with Pixhawk.
At the second thought, I think I am mistaken initially, as you can see from the attached screen shot from ardupilot
showing the GPS port pin voltage.
The 3.3 V I referred earlier is for the Tx and Rx pin, while the voltage across the Vcc and ground pin I obtained from a multimeter is 4.5V and above (depending I power the Pixhawk using USB or flight battery), in kline with the 5V as shown in the attached diagram.
The 3.3 V I referred earlier is for the Tx and Rx pin, while the voltage across the Vcc and ground pin I obtained from a multimeter is 4.5V and above (depending I power the Pixhawk using USB or flight battery), in line with the 5V as shown in the attached diagram.
The other issue with GPS supply voltages that a lot of people miss, is:
Although the GPS electronics actually run off 3.3v (in most cases) the expected supply voltage is 5.0v and there is some sort of crude regulator.
I say “crude” because
a) there’s very limited board space
b) supply voltages below 5.0v start to affect actual GPS performance
And consider that is with new GPS modules. Good luck with the older ones and a poor power-brick!
Or cheap copies…
And consider the 4.7v supply (meant to be about 5.2v) from a cheap power brick goes through at least 1 connector to get to the flight controller, probably two connectors, then another two connectors from the flight controller to the GPS unit. Add in the resistance of those connectors, some noise and ripple, it’s a wonder the poor GPS units work at all.
