First post and my first quadcopter build - and I have an ESC calibration problem.
Config:
Afro20 ESC with SimonK connected to Pixhawk with signal and ground
Pixhawk powered from power module
UBEC powering Pixhawk servo rail
X8R receiver SBUS connected to PC on Pixhawk and RSSI out connected to SB on Pixhawk
some servos and relay switches are powered (no signal wire) from the servo rail
Following the procedure I enter to calibration mode with Pixhawk and hear beep from ESC but moving the throtle minimum no confirmation signal from ESC. ESC/Motor does not react to throtle movement.
I researched the internet and forums but no conclusive suggestion; I tried with (and also without) pushing the arming button.
ESC’s user guide refers my to the flight controller’s calibration process.
Any suggestion please?
