I have build a agriculture setup using cube black running Arducopter 4.0.3.
I just wanna know how the sprayer pump function works in auto mode…
In Stable or Post hold mode the pump doesnt function when you select the servo function as a Sprayer. It only works if u select the servo function as Rc Pass through.
Have any one else used the mission planer and run the sprayer ?
And is there any way we can continue mission from last point after refilling the tank or swapping the battries?
Im really stuck at these two issues
I got it now, MP does not have that function yet. A workaround is to use scripts right? and if I might ask in this post, I keep seeing posts about new features like object avoidance, and master and a 4.1.0-dev version. I tried searching in the wiki, but this link https://firmware.ardupilot.org/devbuild is broken and I still kinda newbie in github, but from I gathered, if I want to use these new features that aren’t in stable yet, I have to download these files in https://github.com/ArduPilot/ardupilot/tree/master/ArduCopter for copter, and do a custom upload/install to my pyxhawk?
Thanks alot,
what confuse me alot is that when you set it up the pump as aux servo and give the DO_SET_SERVO and the Servo Number With PWM value in a perticular way point, does is functional from that perticular way poin to the next way point or will the function remain active for the entier mission?
