Hi, I Built a Hexa with the chinese clone FC, 6s, 360kv motors and a Tarrot frame.
My copter kept flipping backwards and the compass moved in the opposite direction to the copter. Moreover, compass just did not calibrate no matter what I tried, the only way was to use the Large vehicle mag calib option. Suspecting faulty motors, I changed two motors and rechecked connections, board orientations, prop spinning, esc calibration etc. and unable to get it off ground and 6 propellers later, finally replaced the FC.
The new FC (also a clone), seemed to have no issue, the compass moved in the right direction, was able to calibrate compass without any difficulty etc. But when I try to take off, the hexa tips frontwards and hits the ground - 30% power. I rechecked props, motor directions, recalibrated esc, checked if the autopilot compensates in the right direction by simulating pitch, roll, yaw, rechecked CG.
After all checks I tried to test fly, the same happened!
So, being super frustrated, i checked the logs to find out that motors 1 and 5 (very similar in the graphs) run significantly slower than the rest, while motors 2 and 6 (very similar) run faster than the RCIN, and 3 and 4 to an extent follows the RCIN.
suspecting faulty motors, I switched the motors to try and run it, but no change! Surprised, I tried doing more switching of motors, but it all yielded the same results. In general (with slight variations in the graphs when swapped) 1 and 5 runs much slower and 2 and 6 runs much faster!
Suspecting faulty esc, I then tried changing the RCOU! switched 2 and 1âŚbut still the same result!
This pattern is the same when kept on a leveled area, when I try to simulate pitch ( more than 30 degrees approx.) I see that motors 1 and 5 does run muchh faster, meaning they are able to run but is limited by the FC! and I could also make motors 6 and 2 - run at the minimum!
Now, what should I do to make all motors run at the same speed! What are the possible reasons why it behaves this way?! Am I doing something wrong - this the first time I am touching a drone in my life (First time I am using MP, Arducopter, pixhawk etc.) I began building it this Month! I finished building in one week, and I have spent the rest of the time in analyzing and trying to change parts! I am super frustrated at the moment! Please help!
PS - I kinda am a messy person so my Logs are all over the place and have not named them properly, hopefully, I will sort them out and will paste the BIN soon!
Edit -
So, I tried testing it again, recalibrated everything, double checked the prop and motor direction. I did take off without a GPS lock, I donât know if that can cause the drone to flip. Please advice!
Video of whatever is happening: https://vimeo.com/776652203
Log:
test flight fy 680.bin (135.9 KB)
