Do you have mission planner connected? It will show you if you’re actually getting pwm changes on the output chanel of the fc when you are moving the stick. You have to chase through the control, make sure the rc inpit is working to fc, make sure output is working to esc etc
So you can verify the flight controller is receiving the data from the rx but what about the pwm outputs? Have you verified the values change for your esc connected chanel of the fc ?
