I have an arduino to control IR led to trigger cam, and I have setup :
CAM_TRIGG_DIST : 0
CAM_TRIGG_TYPE:0
RELAY_PIN : 50 (AUX1) connected to arduino
also set RC9 (which I think is AUX1 ie PIN 50 ) as shutter in camera gimbal menu
BUT in camera gimbal menu, it says "Please set the CH7 Option to Camera Trigger, but this is not available in arduplane. I haven’t been able to find this under Full parameter list.
It doesn’t seem to work, also is it possible to have another option for manual trigger?
I just wanted to ask if there is an issue with CAM_TRIG in arduplane on pixhawk, When I use passthrough it works fine, but when I try an automatic mission with cam_TRIG I am not getting any triggering.
Thanks again for the help[/quote]
It works for me. I connect the LED to a servo out and assign that RC_ parameter to camera trigger.
I havent tried it using the relay function. It seems like you are making this a lot harder than necessary. I bought the LED trigger from HK for $10, thats cheaper and simplier than a separate arduino.
an LED or an arduino it doesn’t make much difference, because if use a passthrough and manualy use a switch on my transmitter I can activate the shutter. What happens is that the camtrig dist doesn’t seem to work
Is there something wrong with these settings here:
CAM_TRIGG_DIST : 0
CAM_TRIGG_TYPE:0
CAM_TRIGG_DIST must be set to a positive number of meters between triggers. By selecting 0 you have effectively turned it off. Try 1 and you’ll see it triggering sporadically on the bench as the GPS position moves around.
