Hello everyone,
I was wanting to feed the euler angle output (which would be supported by the airspeed sensor) from a pixhawk to an arduino? I was then going to use these angles in a custom stabilization algorithm for my VTOL which would be done by the arduino.
Does anyone know the upper limit of how many unique samples of the three angles (yaw,pitch,roll) you can transfer over every second? I think I will probably be needing to transfer over about 50 samples each second…
Thanks
