The minimOSD is supported for the Pixhawk.
There is a modification that can be performed in order to connect it.
However this longer applies to new minimOSD kits, as they are now including the required cable.
So with the supplied cable, can I just plug the MinimOSD into the Telem2 port (I have the radio connected to Telem1) and go with it? Would any other modifications be necessary?
Indeed Radio on Telem1 (serial 1) and MinimOSD on Telem2 (serial 2)
Original I had a problem to make the OSD to start when I didn’t had the MP connected by using the Radio…
You can fix that by adding Both Transmit and Receive lines from the OSD, so the OSD starts requesting the stream… And this works perfectly in the field…
