Pixhawk 6C Radiomaster Tx16S Telemetry
Hello all, I am trying to set telemetry on my transmitter (Radiomaster Tx16S multi-protocol) from the Pixhawk 6C and using the R86C receiver. From the manal and the mapping, I see it can be done using the UART port but I am curious if it is possible to set it using the PPM SBUS RC port on the pixhawk. If it is indeed possible, what parameter settings would need to be modified?
Thanks,
What telemetry are you talking about?
I am trying to get battery voltage, pitch, yaw… from the pixhawk to the transmitter
I am connected following this diagram on the PPM SBUS RC port of the Pixhawk 6C.
It would the serialx_protocol and serialx_options parameters for telemx (UART) port but I am not sure sure which parameter for the PPM SBUS RC port
Altitude, speed, yaw, battery voltage… from the pixhawk to the transmitter. I added more info in the thread. Thanks
That diagram is showing an Fport Rx, you don’t have that. Those R series Rx’s are limited in capability.
Got it thanks. I’ll be looking for different hardware
Go with a Frsky Rx that supports ACCST like an R-XSR.
