Is any one can show me direction on how to set up Channel to pixhawk 6C mini I/O PWM OUT. thanks
The top row of pins are Signal, the middle row is servo power +v (if you connect it to a BEC) and the bottom row is Ground.
You normally only connect Signal and Ground pins to ESCs.
