My Pixhawk 6C doesn’t turn on when connected via usb or power module. No lights flash. I checked with a multimeter and confirmed that 5v are running to the power cable, which is sufficient power. There is a faint ticking sound coming from the pixhawk when I plug it into power.
So this happens
When only usb is connected and power module/battery is disconnected?
When only usb is disconnected and power module/battery is connected?
When usb and power module/battery are connected?
What else is connected to the FC?
Please answer all questions.
It seems to be a overload or HW defect of the FC.
This happens in all three of those scenarios.
This happens when GPS is connected to the controller and when it isn’t.
Is the GPS he only thing which is connected to the FC?
No other sensors, actors, devices?
If the FC behave so only with a single USB connection, with no other connection; and if the USB power source is good enough I think it is a HW failure of your FC
Thanks. Yes, this happens when only GPS is connected and also when no peripherals are connected.
I’ll reach out to Holybro support.
