Hi. I have some problems with 4 T-moter Flam 200AEsc. I connect with pixhawk-6c
I used external v5 from voltage regulator for red wire
And back and white connect to pwm
But the motors doesn’t run
But when I use recver only the moter run
Any soulion and help
The flame ESC got it own power from Power Distribution Board or direct battery. I think you need ground and signal from the flight controller unit only.
Do you think the red from Flame ESC is providing voltage supply? Use a voltage meter to check.
I used put the withe and black wire to pixhawk-6c
With out using red wire. The T-moter doesn’t working
How are you testing the motors when they are connected to the flight controller?
Have you tried using Mission Planner and the Motor Test function?
Also have you properly configured the flight controller parameters?
Look. I did calibration to small motors with 40A esc
To deron…and flaying
But when changed the motors to T-moter Flam 200AEsc doesn’t worke
Using reciver the moter running with external 5v to red wire and 5v to reciver
But when using pixhawk-6c and connected back and white wires to pwm does not running
Maybe you can try this:
I tryid this and same problem
What motor is that running on 5V? What voltage level then did you supply to the Flame 200A ESC?
please post your connection photos.
Here is a sample wiring diagram, only two wires connecting from ESC to FCU (Pixhawk 6x).
The moter doesn’t running with 5v
It has 3 wire white signal red 5v black GND. The white and black connect to the PWM out in pixhawk-6c
I got the selution
I connect red wire with external 5v
And the external GND to GND pin in PWM out in pixhawk-6c
You better confirm with Flame 200A ESC document, the red is an input or output pin.
We have Flame 60A and 80A, I don’t remember we used the red wire of the ESC.
I got the selution
I hace to give main out or rail servo the External voltage from voltage regulator ±5v
Good. Happy flying. Hope you are correct.
