Hi, i have a pixhawk 4 and im trying to make a boat. I flashed my pixhawk 4 with ardurover on mission planner 1.3.74 but after its done flashing the pixhawk reboots but then the ports aren’t there. i just have 1 port called pixhawk4 in my device manager and it shows up on mission planner as MindPX Com 7 and i cant connect to it. When i flash arducopter or plane it’s working fine im able to connect and setup the pixhawk. Any help would be appriciated.
Issue fixed, someone on github recommended using ardurover 4.1DEV you can do this by pressing Ctrl+Q on the install firmware screen on mission planner. The issue seems to be fixed in 4.1 beta will be out in a month or so for testing.
