I just finished mounting my hexa X6. The setup is:
3DR Pixhawk with APM 3.3.3
Tarot X6 960 frame
Tarot 5008 motors
18x55 CF props
T-Motor 40A ESCs
UBlox M8N GNSS external GPS
FrSKY X9D+ and X8R receiver
10A Tattu 25C LiPo
Everything has been calibrated, from ESC to Radio.
At first flight attempt, in Stabilize mode, I’ve been able to just lift it of 1 cm. (yes, actually not lifted) because the X6 starts to slowly yaw counterclockwise.
The yaw stick from the radio TX does NOT control yaw, despite the radio is calibrated and it correctly reports its values on the APM Planner on my Mac (connected with SIK V2 telemetry radio to the copter).
I tried to use Loiter mode, and the copter flipped backwards upside down.
I remember to have checked the motors wiring according to Ardupilot Wiki, will double check today.
Anyway, what could be the problem?
Another strange behaviour is that APM Planner reports me FCU errors randomly: bad accel health, for instance, but if I power cycle the copter, it disappears.
If you can get the log off the copter and post a link from google drive or one drive we can see what was going on. A slow yaw seems to indicate a motor is not level and is pointing in that direction.
Your configuration will not fly. All your PID values are zeroed out so there is no control. I would follow the instructions on the following page to reset your PID’s to something that should fly.
Thanks @iseries your support is decisive. I asked before to setup but it has been told me that I could keep the PID at zero…
So I will reset them tomorrow. Can I just copy the settings or do I have to reset the Pixhawk and setup again the radio?
If you know what they were you should be fine otherwise they will be populated with the defaults if you a reset. I would recalibrate everything since a few items looked off.
