After running
mavproxy.py --master=/dev/ttyAMA0 --baudrate 57600 --aircraft MyCopter
and
Disabling serial port in Configuration->Interfaces.
enable_uart=1 in config.txt. sudo nano /boot/config.txt
I get the result:
“Waiting for heartbeat from /dev/ttyAMA0”
Does MAVLink even work on Ubuntu 16.04 or is it just made for Raspbian Jesse? I need Ubuntu 16.04 because I do not know if it is possible to use ROS and OpenCV on Ubuntu 16.04.
