Xerravon
(Xerravon)
September 26, 2016, 10:22pm
#1
I just ordered a Pixhawk 2. I just realized it has different connectors on it. I have found somewhere said it uses jst gh connector, Is that the 1.24 size? Or is it something else. also wondering what I will need how many pins?
does anyone know where to get premade or pre crimped cables?
thanks,
John
BigTulsa
(Mark Brummett)
September 27, 2016, 1:06am
#2
If you ordered it, the new kit will come with cables that will work with the old DST connectors.
Xerravon
(Xerravon)
September 27, 2016, 10:59pm
#3
Hi, Thanks. I ordered one from Proficnc. I do see it says it comes with a cable set. I dont know why I didnt see that when I ordered.
I did order some connectors and contacts from digikey, just hope my crimper will work with them. if I ever need them.
I am going to replace a Pixhawk with this one (then put the pixhawk on a copter I am still using an apm25 on.
thanks again,
John
edge540T
(edge540T)
November 3, 2016, 6:41pm
#4
I just take place to see how we can adapt, a see power bec’s compatible for 8-14S
edge540T
(edge540T)
November 29, 2016, 5:32pm
#5
Just to be sure, power module with xt60 connector is up to 8S as I read somewhere. Isn’t it?
mboland
(Mike Boland)
November 29, 2016, 8:00pm
#6
Yes, 8S 30A I am told is the rating for the Power Module.
BigTulsa
(Mark Brummett)
November 29, 2016, 8:51pm
#7
Wow, 30A? That’s not a lot. However 8S is good.
I have the 100A Mauch. Good module.
edge540T
(edge540T)
November 29, 2016, 10:42pm
#8
Ups! Are we sure? 3DR was 60A(apm 90A) reading, on the big one will use Mauch for ph1 but for the liltle one I have doubts if it is only 30A
Jagger
(Jagger)
January 26, 2017, 3:05pm
#11
Hey edge,where did you get those wiring drawings.I haven’t found anything quite so clear.
Jagger
(Jagger)
January 26, 2017, 4:07pm
#13
Thanks.Where do they come from ?
I’ve found it hard to track all the info down so far.Not too different from the Pix 1 but different enough to be careful.
edge540T
(edge540T)
January 26, 2017, 4:38pm
#14
Bruce
(yi deng)
January 26, 2017, 6:08pm
#15
the connectors called DF13 JST MOLEX
Jagger
(Jagger)
January 26, 2017, 7:30pm
#16
Thanks Bruce.
Molex Clickmate I heard,or is that just the power connectors ? .My JST-GH (Pixracer/Pixhack) plugs fit most of the sockets.Nice connectors.
The non power connectors are not click-mate or DF13 but JST- GH 1.25 pitch. I ordered click -mate in error.
