How do we connect Pixhawk 2.4.8 with FS-iA6B receiver?
My current connection is from Pixhawk (RCIN) to receiver (PPM/CH1). But the LED on receiver does not blink.
After watching several videos and reading online about this, it seems that I am connecting it correctly, but no matter what, it does not work. Receiver works fine if connected to ESC+Battery. Can someone suggest if I am doing something wrong.
In order to use SBUS rather than PPM I think you want to connect it to the top right three pins on the receiver (with the connector flat, signal wire to the outside) in order to get sbus. Then on the TX select sbus rather than ibus.
My controller is the same and to use PPM, I need to use a PPM Encoder, I donβt know if itβs possible to connect without the PPM Encoder, but it works perfectly for me.
