And I bought 4x Holybro Tekko32 F3 35A ESC BLHeli_32 (Supports Oneshot / Multishot / Dshot), with rctimer 5010-260kV motors.
A followed first the documentetion connecting the pixhawk for the “connect-escs-and-motors” part. But the the throttle does not change the motors speed, and BLHeli Pass-Through does not work.
Then I read somewhere that I need chibiOS firmware and need to put the ESC signal to the pixhawk AUX ports (1-4). So I installed chibios, and changed the ESC connections.
Now I can access the ESC-s trough BLHeli Pass-Through, but If I arm the copter, the motors start to spin on the basic speed, but the throttle does not change the motors speed.
I also try to use a Little Bee ESC, but it works the same as the Holybro ESC.
(I used the motors test in ground station, to test the motor connections are in good place, and yes, the good motors is the good output.)
Can someone point me the good direction please? Or show me a documentation?
This thread is about disabling Low RPM Power Protect for low kV motors. But, you have BLHeli32 ESC’s, have set the BLH parameters in Mission Planner and passthrough is not working with BLHeli32 Suite?
Do you use blheli32suite? There need to be select the correct blheli_32_interface, and then select the correct com port then press connect, after that press read setup. You need to see it reads the ESC parameters.
