For some reason my Motor dos not start spinning until after 35 to 40% on Stick
Things I have tried
2X Calibrate Radio
3X ESC Calibration using this Method https://www.youtube.com/watch?v=Hl-Q7RPOn18
Check Fail Safe Settings and set Fail Safe Works
Not sure what to try next.
Thanks in advance for any help
what mode are you in, try stabilize
Same affect in stabilize or manual also I have throttle set to pass thru in stabilize I find it a nice way to stall land my RV jet when I only have short landing area
SOLVED was using a old Calibration method should have read http://ardupilot.org/plane/docs/quadplane-esc-calibration.html
