Hi, i’ve a problem with my Hexa and no one i know can help me. i’ve replaced the naza v2 of f550 with pixhawk 2.1 and gps here motors are dji 2212 920kv and tarot short landing gear (by me blamed of the problem) sometimes with the wind when landing even with the throttle to the minimum some motors start (asymmetrically) and tips (does not turn off and knock the propellers) does not do it or does it less less in alt hold. Is there a full params option to lower engine disarming time when landing? I did the tests and it does not depend on me … in RTL I did do it to the ground with bad results …
Someone says it is the fault of the original pixhawk 2.1 proficnc that has barometer problems … others tell me it is the fault of esc and dji motors … i accept tips … thanks!
P.S. in Loiter mode the hexa behavior is worse than alt hold mode
P.P.S. PILOT_THR_BHV: Throttle stick behavior can help me?( i’ve not change it value yet, to avoid further problems)
P.P.P.S. i’ve lowered the value of landing final speed to 30 cm/s (the min possible)
thank you in advance
