Hi All
I am using Pixhawk 2.1 ,
ArduCopter v3.5.2
In the Full Parameters List , INS_PRODUCT_ID is set to 0.
Is it default?
Any comments ???
Hi All
ArduCopter v3.5.2
Is it default?
Any comments ???
Yes, I think line 59 of AP_InertialSensor.cpp indicates that 0 is the default value.
Yes i see there
old_product_id=0
There should be some number .
I think perhaps I don’t understand your question… Could you explain what you are expecting the value to be, or why you don’t think 0 is an appropriate number?
In Mission Planner >> Config/Tuning Tab>> Full Parameters List
There are options for INS_PRODUCT_ID as
3: SITL
4. PX4v1
5. PX4v2
etc
So i was expecting Option 6 for PX4v3 [Pixhawk 2.1]
Ah, thank you! I think I understand your question now. I am not a dev, but I believe the confusion comes from you using old firmware (3.5.2) on newer hardware (PH 2.1).
One important thing I found is that I think those product id’s have been deprecated and removed since 3.5.2 came out back in March 2016. Here’s the commit, dated Sept 2016, that seems to have done that:
commit 6b88f3367bc4d91432939cce629da01aed6876f2
Author: Lucas De Marchi lucas.demarchi@intel.com
Date: Sat Sep 3 12:40:40 2016 -0300
AP_Common: remove AP_PRODUCT_ID_* macros
These are not used anymore.
But if we look back at the source of 3.5.2, I think lines 161–170 of AP_InertialSensor_PX4.cpp should set your INS_PRODUCT_ID correctly. From lines 127–136 of AP_Common.h, I see that 0 should correspond to Hardware-in-the-Loop (AP_PRODUCT_ID_NONE). My guess is that the product id for a Pixhawk 2.1 should be 5, corresponding to AP_PRODUCT_ID_PX4_V2. Perhaps someone else can verify, or correct me if I’m wrong?
But the key is your older firmware version: If you are having problems, I recommend you update your firmware, which should make this issue go away.
