I received a Pixhawk 2.1 on Nov 23rd (a lucky early bird). Everything was going fine, until a week ago! I followed the service bulletin when it came out. I had a Here+ unit on it at the time, but wasn’t running 3.5rc to use it. Instead, I was going for stability, on AC 3.4.5.
The setup was flying a pre-planned mission without human intervention. It had completed this same flight about 5-10 times perfectly before this flight.
My current prognosis is a motor failure (specifically on RC_OUT 5). It’s odd that this happens to also be the channel related to the pixhawk2 bulletin…
Can someone help walk me through to rule out anything related to the Pixhawk 2.1 bulletin?
nothing special about the code. the code allows you to configure your copter in lots of different ways, and gets used lots… so I dont think so… nothing is impossible, but this is highly improbable
