Pixhawk 2.1 does not come up
Please help,
my pixhawk2.1 does not boot after a uprgade.
How can i reset or factory-reset the device?
The device blink short green after power up, but then immediate blink fast red.
Sounds for my like a unstable power, but the battery is plugged in to the power1 slot.
is there a possibility?
thanks,
smilie
check if you didn’t accidentally disconnect your SD card, its right under the micro usb plug
MissionPlanner works QGC works not.
I get a idea from “MyPixhawk-forum” to use a trunk version for qgc, because the chibios-bootloader is new.
I try this and will post success or issues.
Thanks
