I looked up the meaning of the various LEDs, but can’t find out what a steady blue I/O ACT means (the bottom of the three leds in the uppper left corner). Normally it blinks at 2 hz. Mine is a steady blue, which I think indicates a malfunction.
You need to be a little more specific. The Pixhawk design was used by many manufacturers and many used different colored LED’s than the first versions. What exact version of Pixhawk are you inquiring about.
Thanks for the link. I’ve read through that a few times previously, but cant find anything about a steady blue LED, Its supposed to blink at 2 hz, but mine is solid blue.
Thanks for following up. I did see that but prevoiusly ignored it because I wasn’t uploading firmware. However, I did try uploading copter ( I had plane loaded) and that seems to have fixed the problem,
Now I have another problem. I can connect to the pixhawk loaded with copter but not when plane is loaded. The middle I/O LED is solid amber with plane loaded and off when copter is loaded. Not sure why?
Can you describe what procedure you use for loading the (correctly-working) Copter and the (not-working) Plane firmware?
Are you able to try uploading a different version of Plane, or uploading it in a different manner? (e.g. use QGC rather than Mission Planner, or compile-from-source, or something)
Same procedure for both versions of firmware using mission planner. I even tried loading rover - it worked, no problem .
I upgraded to the lastest version of plane. I loaded the previous version of plane and still couldn’t connect with plane loaded. I can connect with copter and rover loaded, but not plane. Wierd!
If I had your problem, I’d try using QGroundControl, or learn to compile-and-upload from the source, see if the results are any different. It might (or might not) be worth you learning to use these methods to see what you can learn…
