I buit 2 drones, both with very similar hardware
Pixhawk (HK clone)
M8N GPS
One is a quad, one a hex.
The Quad so far has worked just fine.
On the hex, it is another story.
The first battery works fine. It acquires GPS signal, I take off, flys good, GPS modes (drift, hold, RTL etc.) work fine.
I land, take off the battery, attach a new battery and take off again. It is without power anywhere between 20s or 5min, doesnt matter.
Now I take off in stabilize, everything works fine. As soon as I switch to a GPS mode (drift, hold RTL etc) it “leans” to the side and drifts off in a random direction. In RTL it fails and switches back to stabilize, in hold as well sometimes.
Yes it showed 12sats via telemitry link - HDOP was also ok, I have not overridden any checks, when it has too few sats or bad hdop it does not let me switch into GPS modes at all.
I cannot swap the GPS because of different mounting.
What irritates me is, that it works flawlessly on the first battery. no drift in any direction on hold, “drift” mode flys amazing, RTL (thank god only for fun, no “oh shit” moments) works as intended. Only when I unplug the battery connection does it make problems.
