I am attempting to build my first Discovery Pro TBS with the PixHack FC and T-Motors 70amp ESCs - planning to haul some big batteries under some 18" props.
I cannot get the motors to run.
When I unlock with the button - the safety button turns from flashing to solid.
The status led is GREEN
There is a solid long beep from the drone when the sticks are put in the startup direction.
Then the status LED goes out and the pixhack reboots.
I have tested the ESCs on another FC and they work fine.
I have removed the ESC wires totally and the system still has the problem.
When I run the initialization setup in mission planner using the wizard i get to the final few screens and everything is checked off green.
I don;t know what I am missing and I don’t know if this is enough info for you. I tried SEARCH but I couldnt find an answer.
Thank you for any help
chris
