Today I tried acro, moved pitch/roll acro P to the max 10 and added 80% expo to pitch/roll.
Even at rate 10, flips are not fast enough…
2 time after I flipped somehow the pitch got reversed, almost crashed, moved to stabilize and it helped, the quad leveled and the pitch returned to normal.
I was using Acro with Acro trainer for leveling only.
Attached is the log, I couldn’t see the problem, I hope I have the right one.
Could you try to reproduce the problem with RCin and RCout turned on. I can’t tell from your logs if you commanded the pitch in that direction or not.
I can however tell you that your copter is being limited by the copters physical ability to accelerate in roll, not your commanded rate. I can see that your copter is being told to move but is unable to get up to speed quickly enough to follow your command.
I can also see you have quiet bad vibrations however this could be because you have set your filter to 98 Hz. I would not expect your Alt Hold to do well.
