After calibrating the arducopter installed on my quad copter, I was checking the movements on the mission planner and the pitch is reversed when check in the HUD of the mission planner. I have calibrated it a few times now its still the same, I am not sure what I am doing wrong. Is there a way to reverse the direction of the pitch ?
You can reverse pitch by changing RC2_REV to -1 (if I recall correctly - copter.ardupilot.com/wiki/arduco … se_RC2_REV) but you should be sure to check first if it’s not just your radio that needs pitch reversed?
Don’t know if you’ve solved this yet. But take your mouse place it over your HUD. Right click on HUD. In the drop down menu, left click on Russian HUD. This should solve the problem. I don’t know if it will affect flight characteristics, but your HUD will move correctly. If anything seems funny Click on Russian HUD again to reverse it. Hope this help someone.
