I’m designing a quadcopter with tilt-rotor but am unable to figure out to which pins of my Pixhawk I should connect my motors to and to which I should connect my tilting servos.
I am planning to use 1 servo per motor and not using anything except the 4 motors of a Quadcopters and 4 servo motors to tilt them forward and backward.
What parameters should i set, other than ‘Q_ENABLE’,‘Q_FRAME_CLASS’,‘Q_FRAME_TYPE’
In the paragraph labelled explains what you need to do in my case i decided to plug my tilt motors into Channel 9 and 10 on mission Planner SERVO9_FUNCTION=41.and SERVO10_FUNCTION=41. and motors into outputs 5 to 8
With Mission Planner you can set any output to any function
