i own a Cuav V5+ with 2 hv power modules from Cuav.
Because the flightcontroller only supports one power module I have chosen pins 13 and 14 as inputs according to the wiki.
But I do not receive any data under the status screen.
Can anyone help me here?
I know I’m definitely using these pins on a CUAV V5 Nano:
ADC Pin1 -> Battery Current Sensor
ADC Pin2 -> Battery Voltage 2
Since I rigged up a different battery voltage divider circuit. The CUAV current measurement was quite accurate but I had an issue with the battery voltage measurement of the HV PM module.
thanks for your answer.
The Nano has a slightly different design than the V5+.
Therefore I can’t compare it directly.
I have attached screenshots of my settings below. Maybe someone can solve this problem for me.
