I got stuck on finding a power system for powering Pixhawk 6X and several servo by 10S 20000Ah Lipo. What power system (maybe including PDB, powermodule and BEC) is compatible to these requirements? Any information would be helpful.
Thank you
Mauch current and voltage sensors.
With those Hall sensors for current, there is one that reads up to 200 amps (for example) but it is not phsyically limited to passing only 200 amps, like a shunt resistor type of sensor would be. The Mauch/Hall sensors can usually pass more current than they can measure for a short time.
Yes, that is probably OK.
Once you get to that sized wire, the wire cross-sectional area is unlikely to be your limiting factor in relation to small UAS. Connectors, any connector whatever the size or advertised rating, will be significant too - and probably other things like your soldering and thickness of tracks on circuit boards.
