I have a bit of a strange problem. I’m working on a drone which should use two RC protocols for demonstration purposes. The current plan is that there is always only one turned on. I’m using a Pixhawk 2.4.8, on the RCIN Pin I have a FrSky X6R and on Serial2 I have an ELRS Receiver. I also would like to have Yaapuu telemetry running on my radio, therefore I have a Passthrough converter on Serial1 with Protocol set to 10, on Serial2 I have the protocol set to 23 and the RC_Options bit for “use passthrough for CRSF telemetry”.
But I can’t get the Telemetry working on both, as soon as I enable the second I get the message “Passthrough telemetry conflict”. I understand that my case is an edge case, but shouldn’t this work when using RC_Options Bit 10 (Multiple Radio Control Receivers)?
Is there maybe a workaround by detecting which receiver is currently on and setting the according parameters via a lua script at startup?
Thanks
