That’s a big battery for your first build. You might be better off with a couple of smaller ones wired in parallel so if you have a charging incident or run one low at least you will still have a battery left to work with.
If this is the same Usbasp used for flashing the KK2 than I just purchased it one for 9 $ with the 6 pins adapter, and I am pretty sure you can even find a cheaper price.
[quote=“GaryMortimer”]Yes the battery, charger and leads will work.
Thanks for the response. I have researched about the batteries and it can hold it + gopro. I think ill get parallel and a big battery. Also I’ve added the alarm incase something happens. Thanks for helping me out.
[quote=“frejus”]Is the 9rx programmer really 45 $ ?
If this is the same Usbasp used for flashing the KK2 than I just purchased it one for 9 $ with the 6 pins adapter, and I am pretty sure you can even find a cheaper price.[/quote]
Yeah its 45 total shipping included. Ill see what I can do, I’m afraid ill mess up with the soldering inside the tx
@Ponwer
What do you want to do with your multirotor is the first question to ask yourself.
Than my next question would be why do you want to use hexacopter instead quadcopter as your first multirotor?if its abut payload I am sure you can build quad with same payload capabilities, for GoPro camera for sure and Sony nex as well…for bigger dslr alike cameras you want to have an Octocopter
I would suggest quad copter and later you can always add 4 more motors and make coaxial octa copter(two motors on one arm…
That frame and props and motors might be good a year or two ago but not today
vibrations are big, motors are weak and props is cheap plastic ones…
I know for you as a beginner it looks nice to buy ARF model but that is always a mistake
and use expensive batteries bcs it will last u 4 times longer than Turnigy nanotech shit,Zippy are a little beter and it wil last longer
for this setup u will need 4s 5000-10000mAh + I would suggest GensAce,one of best u can buy gensace.de/lipo-battery.html … oltage=148
there is USA shop as well…
for 10 000mAh it is better to buy 2x5000 and have more discharge rate when u connect them in parallel and also if you fck them up somehow it will cost u less
for best flight time your frame and everything on it(motors esc wires gimbal camera)has to be same wight as batteries(1:1) or at least frame:payload:batteries 1:1:1
also do you calculations with this,but I think 20+ minutes of flight is possible ecalc.ch/xcoptercalc.htm?ecalc&lang=en
if u need any help be free to ask…good luck
