I installed ardupilot 3.8.0beta on the parrot disco and everything boots up and communicated fine with my GCS but It does not respond to gamepad input. is the build of disco not include ALLOW_RC_OVERRIDE mode or what is the problem?
is there a way I can test to see if the arduplane accepts override messages?
I can arm it too but there is no response to throttle or roll or pitch commands
Basically when I use qgroundcontrol it says this
"Joystick support requires MAVLink MANUAL_CONTROL support. The firmware you are running does not normally support this. It will only work if you have modified the firmware to add MANUAL_CONTROL support."
How can I add Manual_Control support to my disco arduplane build?
it should require time to develop ! Connect to SC2 with usb to ethernet 10/100 cable (note that limited devices usb to ethernet are supported, 10/100/1000 will not work and some 10/100 as well).
It’s better to connect another joystick or a small RC with sbus
@kikislater, @julienberaud when connecting to Skycontroller2 with Ethernet-USB stick, it gives me this:
$ifconfig
eth0 Link encap:Ethernet HWaddr 00:E0:4C:36:01:FF
inet addr:192.168.53.1 Bcast:0.0.0.0 Mask:255.255.255.0
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:34143 errors:0 dropped:0 overruns:0 frame:0
TX packets:32939 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:1606213 (1.5 Mb) TX bytes:2025224 (1.9 Mb)
wlan0 Link encap:Ethernet HWaddr A0:14:3D:CB:BE:DC
inet addr:192.168.42.3 Bcast:192.168.42.255 Mask:255.255.255.0
RX packets:0 errors:0 dropped:0 overruns:0 frame:7743
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:0 (0.0 b) TX bytes:0 (0.0 b)
$ netstat -an
Active Internet connections (servers and established)
Proto Recv-Q Send-Q Local Address Foreign Address State
tcp 0 0 0.0.0.0:21 0.0.0.0:* LISTEN
tcp 0 0 0.0.0.0:6007 0.0.0.0:* LISTEN
tcp 0 0 0.0.0.0:44444 0.0.0.0:* LISTEN
tcp 0 0 0.0.0.0:7711 0.0.0.0:* LISTEN
What are these ports for, what services are running?
How does Skycontroller know to which Wifi connect and which not?
Does it mean that SC2 is a wifi range extender / router?
Can it be used as such with other wifi devices?
@Fran , try QGroundControl. I have seen it working on Parrot disco in the following configuration:
XBox 360 game controller
connected by USB to a Linux Ubuntu Laptop
QGroundControl running on the Linux
Linux machine connected by Wifi to the Disco running the latest ArduPlane software.
On/Off button special pattern press was necessary to stop the stock autopilot, which behaved almost like arduplane but didn’t accept commands, and to start the ArduPlane.
Only problem was that when Disco flew out of range of the Wifi, it wanted to turn back immediately and land in RTH mode. Lots of fun.
If you want to increase distance, you should buy a usb wifi card.
I fly with ALFA AWUS036H to increase range. I have 1.5 to 2.3km depending on environment.
I already try TL 722N, a bit less range but still reliable. Problem is when you have suddent drop in wifi … Sometimes difficult to recover if you are out of range.
