Parameter loading screen problem on mission planner
Hi;
I have an Omnibus F4 Pro autopilot. Ardurover version 4.5.1 installed and Beitian Bn880 gps module connected
When I try to connect to the autopilot with Mission Planer, it stays at the parameter loading screen.
When I remove the gps module and try to connect, it loads all parameters. The cable connections of the GPS module are correct because I can see the gps fix message on the MP screen.
When I wait for it to load, as you can see in the second picture, it tries to load the parameters again on the Already got param screen and so on in a vicious circle. Does anyone have any idea why this might be happening?
Did you update the firmware from a much older version that was previously flashed and configured?
no, I updated from 4.2.1, but the problem was there in 4.2.1
