I build firmware 4.4.4 in ubuntu for both CubeOrange and CubeOrange+, successfully build and working fine onboard.
I noticed a issue after using apj_tool.py program. both the built arducopter.apj does not show default parameters which was embedded in building process,
But when I used same program for /Copter/stable-4.4.4/CubeOrange it shows the parameters
I also tried to add default custom parameter file "successful " but can’t be seen through this apj program…
How many parameters are on those files? It only supports around 200
Thankyou, not more than 50 custom parameters
