Hello to all. I plan to use the aircraft for automatic flights with a camera, I installed a parachute on it. I tested the plane in the manual and found a problem, with a sharp turn, my parachute opened. began to understand and noticed that in versions above 4.1, the chute_crt_sink function was added. I had a value of 5, and apparently I exceeded this sink rate. I would like to disable this feature altogether, but I did not find in the documentation how to do it. I hope you have some advice. I believe that setting chute_crt_sink = 0 will disable this feature, but I’m not sure.
