Any time I try and open a log that contains data, APM crashes. If the log is blank, it will open the log and display a blank log, but if there is any information contained in the file, the program will crash. Mission Planner on Windows does not have this issue, this issue occurs with about a dozen different logs, its not specific to a given log.
Attached is an txt of the crash details (in a zip, because I can’t upload just a txt file apparently).
Using the 2.0.19 nightly build, the error still happens.
I can’t imagine deleting or replacing preferences caches or other dependent files would make a difference, would it?
In the crash report, I am unsure if this is the section of relevance, but it looked like it might be.
