OSD Help
Hello, I recently built a 450 with the 2.6 controller. I have added telemetry which is working great, but now want to add OSD. I have the OSD but was a little confused at the setup. First do I need a programmer for it and if so where is the best place to buy it.
Also I will be using my Gopro which I do not power from the copter. I have a fatshark 250mw transmitter. My question is do I need to supply 12v to the OSD for it to work and can that be directly from the LIPO.
Thank you
Grandpa Jake
You need a programming FTDI cable to update the Firmware on the OSD board and also to be able to configure where things are displayed and what is displayed.
store.3drobotics.com/products/ftdi-cable-3-3v
The config software is free and can be found here:
code.google.com/p/arducam-osd/
Yes, you need to supply 12V to the OSD video side. The cable that you use for the GoPro does not have that pin connected. You need a 3 conductor cable from the Transmitter to the OSD board.
store.3drobotics.com/products/se … ale-female
Mike
