Spacers are just touching
If you can move the battery to the bottom of the build.
Set these:
INS_HNTCH_ATT,40
INS_HNTCH_BW,18
INS_HNTCH_ENABLE,1
INS_HNTCH_FREQ,36
INS_HNTCH_HMNCS,7
INS_HNTCH_MODE,1
INS_HNTCH_REF,.139
INS_LOG_BAT_MASK,1
Then set this to 2, make another short flight to see how well the filter is working.
INS_LOG_BAT_OPT
Auto Tune one axis at a time and charge the between axis.
Yes, 4.1.0-Rc1 is what you should be using for fast Auto flight. But there are several considerations and parameters to set.
He probably has a bottle dropper on the bottom. You can assume that if someone is posting from Turkey and they have questions about fast autonomous flight they will be at TEKNOFEST.
After I set INS_LOG_BAT_MASK to 2, do I enter the new settings and then set it to 3?
Where can I get the parameters I need to enter in 4.1.0?
No. You set INS_LOG_BAT_OPT to 2 and make another hover flight after making the setting changes. Then review the results with FFT to determine if the filter parameters set are working well.
I understood very well, I can’t thank you enough.
INS_HNTCH_REF=139 are you sure, MP range shows 0 - 1.0
That’s not what I posted. Look closer.
INS_HNTCH_REF,.139 I think this is 0.139, got it.
But even if I entered this value incorrectly, the vibration level decreased a lot.
I guess there is no problem.
https://drive.google.com/file/d/1XSne-bjA6JHA37VYc-jhrgG1PUQp6QKP/view?usp=sharing
I would only be interested in reviewing the log if the Filter reference hover value was set correctly. Otherwise you are simply looking at the Low Pass filter.
