I’ve been doing a deep dive into WebODM for photogrammetry processing.
I’ve learned that WebODM has the ability to convert yaw, pitch, roll data to omega, phi, kappa values for image orientation.
I’ve never found a EXIF viewer that displays either yaw, pitch, roll - or omega, phi, kappa in an image EXIF.
I do know that Pix4D has the ability to convert orientation from a DJI drone’s images to omega, phi, kappa values. It does not do so for Mission Planner geotagged images - neither will it do so when the geotag data is taken from the Mission Planner geotag CSV geolocation file.
Is it possible to confirm if the Mission Planner geotag routine does add yaw, pitch, roll data to each image - and is there a viewer that allows seeing this data?
There is a small wrinkle in this. When camera’s are attached with a fixed NADIR mount, the pitch data would be of the aircraft - hence 90 degrees off for the image.
I’m trying to get the WebODM dev’s to help in my understanding of what’s happening on this matter.
The thread I’ve created is here:
It would be really helpful to get some clarification on what Mission Planner’s geotag routine does with the orientation data. I know it’s available in the CSV geolocation file. But I don’t know if any such values are actually added to the image EXIF data.
If anyone could clarify what’s happening here, I would greatly appreciate it.
Digging into this a bit further, I’ve learned that WebODM has the option of using a text file with geotag and camera orientation values for processing the location and position data. WebODM refers to this file as a geolocation file.
The format of this WebODM file is very similar to the text and CSV files that the Mission Planner geotag routine produces.
I might suggest that Mission Planner have an option to generate a file that meets this specification - but its such a simple change, perhaps its best to let the operator make the necessary modifications to the file.
Letting the operator do this would allow changing some of the values - for example, where a camera is fixed in the NADIR position, the pitch value would need to be changed 90 degrees from the drone’s pitch.
Processing Mavic 2 Pro images with WebODM - with and without the camera orientation values, I find that with the camera orientation values the point-cloud with the camera orientation values has about 20% more points. This is valuable.
Here’s an excerpt from the WebODM manual that explains the format of it’s geolocation files used for this data.
