The problem is about compass. I’ve done all the compass calibration.
But A compass inconsistent occurs when the head is turned in a specific direction.The direction is constantly changing, and compass errors may occur in all directions.
This phenomenon disappears except for the internal compass, is it a cube problem?
Just to clarify that a bit (probably not for Allister, I’m sure he knows), the reason for flight controllers seeming to have such poor compasses is because they are invariably mounted extremely close to all the high current wiring and batteries.
The GPS units with a compass have a good chance of working much better because they have an amount of separation from all those strong magnetic fields.
It is typical to disable the internal compass for that reason.
Also the internal compass can work acceptably if you do the Compass/Motor calibration, either by the dangerous method, or using MagFit.
