I have a black cube that I use for testing that I could use to program the ESC on this bird. That said we plan on making quite a few of this aircraft and I was hoping to streamline the manufacturing process as much as possible.
I’ve added this to the Copter-4.0 issues list so it won’t be forgotten.
It’s very clear that the BLHeli/DShot setup is too difficult. I personally think we’ve got multiple issues going on and we need to identify and then knock them on the head one after another. We’ve got a small change coming which helps users figure out what the board thinks it’s outputting so this will hopefully allow users to identify more quickly when there’s an error in the config.
I’m going to take a random shot in the dark that the issue with using BLHeli on the OrangeCube has something to do with the new high performance boards (CubeOrange, Durandal) presenting two COM ports. I suspect either the BLHeli suite or our passthrough is going to the wrong one. Anyway, we will investigate!
Just an FYI…
When you enable CAN On the CUAV V5+ cube flight controllers (assume others as well) you are also presented with two serial ports. One is for normal mavlink and the other is SLCAN that is used for directly accessing the CAN devices, similar to the UAVCAN software
…Dont you need to set SERVO_BLH_OTYPE to 4/5/6/7? Even if _AUTO works, I dont think it sets the output type.
set SERVO_BLH_OTYPE to 4 (= DShot150).
https://ardupilot.org/copter/docs/common-dshot.html#configuring-dshot-esc-protocol-output
…and the_AUTO didnt work for me, I had to set it manually with _MASK:
Use SERVO_BLH_MASK to enable BLHeli_32 pass-through and telemetry support on non-multirotor motors and / or exactly specify which servo outputs you want to enable BLHeli_32 pass-through and telemetry on.
*Edit: Disclaimer: I dont have an orange cube
There does seem to be a issue with BLH passthrough not working on the CubeOrange, the Dev - Team is working on it, hopefully we will have a fix soon.
I can verify that passthrough works with 4.0.2 on my Omnibus nano v6.
I can verify that passthrough works with 4.0.1 Pixhawk 3 Pro and doesn’t work on the Cube Orange
Copter-4.0.3-rc1 has a fix for BLHeli passthrough on CubeOrange. I think you’ve tested that PR and found it works. Can you re-test with Copter-4.0.3-rc1? If it doesn’t work, could you re-test with master?
I was wondering if you could post log files? I’d like to see the parameters and also the “RCOut:” message which will tell us what outputs the autopilot thinks it’s using.
ok, what exactly do I do to record a log file?
The easiest way is to set LOG_DISARMED = 1, reboot the autopilot, do a short test and then connect to the autopilot with MP, go to the Data screen, DataFlash tab on the bottom left and push the “Download over Mavlink” button. Then find the file and post it here (or link to it here). Some instructions on the wiki here.
Also feel free to set LOG_DISARMED = 0 once you’ve got the log file.
@rmackay9 Can confirm the baud rate is now correct on Copter-4.0.3-rc1, didn’t test on an actual ESC but with the correct baud rate it worked on master so I’m sure it’s fixed.
Don’t have an Orange Cube but I have found on my Dell laptop running Win10 that I can only use USB2 bus. If I plug into USB3 BLHeli Suite will not find ESC’s; it seems to want to try to talk to my USB mouse.
Slightly off topic, but I must confirm what Coby wrote, a lot of devices don’t like USB 3.0…
I had problems with my Taranis X9D, as well with a rPi 4. A simple USB 2.0 hub will resolve a ton of problems, although they seem hard to buy nowadays…
