I moved it in both roll and pitch, as I was trying to follow the instructions in OP it is linked there. Since my graph does not match up, I might try in flight if I can not get it to work through log based calibration. Did you also use a Mateksys 3901-L0X as I’m using this one with a quadcopter.
I did try changing the scalars and nothing happened. I think yaw for me is 0 the way the sensor is positioned. As for IMU calibration, I am not sure about that, where can I calibrate that again?
