I’m trying to fly a quadcopter autonomusly indoors using a optical flow sensor, but I’m getting quite erratic results trying to fly in Loiter. I’ve followed the guide from the docs, and I seem to get good data from the flow sensor when I’m flying in AltHold. I’m not sure the copter is using the sonar data though, flying over tables I expect the drone to gain height but it does not. Take off is heavily affected by ground effect, I’m seeing a lot of bouncing and altitude drift. I know sonar is supposed to be bad, but this is on a hardwood floor, surely it should work fine?
This log is of my latest flight where I ran into issues. The drone started off having a hard time initially getting off the ground, after which it drifted wildly before I got it to land. Once on the ground it started spinning up once again (throttle is at minimum at this point), and once I got my foot on the copter, the motors started spinning at high RPM until I got to the safety switch.
Hello!, I’m new to the arducopter and I’m working on a project where I have to control a quadcopter but I wan wondering how are you sending orders to the drone cos my Idea right now was to hack a controller to be controlled by a computer but if there is a way to send orders directly to the quadcopter instead of using a control as a bridge would be faster, Is it possible to use live mavlink commands or is there something else that I should be doing?
You can set RC overrides to give fake controller input, no need to hack a
controller.
The better way is to use the global move commands, I can’t remember right
now but peruse the mavlink docs and you’ll find them. These commands assume
that you’ve set up your state estimation correctly though, so double check
that beforehand!
i am currently working on a similar project, flying a copter indoors with pixflow. The copter is supposed to fly in a factory hall with lots of obstacles like machines. I don´t want the copter gaining and loosing height while flying over obstacles, the height is supposed to be controlled manually. Is it possible to use the pixflow module with only the camera ?
