Still concerning the OMNIBUS F4 Nano V6, After playing around with the 3D printer a little bit to get a few parts for the camera gimbal and legs for the quad, I decided to go and install the newest version of arducopter firmware ( 3.6.11) in the OMNIBUS F4 NANO V6.
Now… I’m not sure anymore if it ever worked… but I’m having some trouble getting the Battery monitor to work. As soon as I try to activate it I get “This feature is not enabled in your firmware”.
So… that’s definitely not a good sign. Have you ever got this kind of error? What I found in on the net is that most of the times people with similar problems just end up trying different firmwares and sometimes it works and nobody knows why.
I accidentally upgraded to 4.0, but now my Beitian BN-880 is in Bad signal health. Maybe version 4 does not support omnibus V4? Or do I have to change some parameters?
I would recommend posting about it here as this is where you are most likely to get help with this:
To answer your question it should work and you shouldn’t need to do anything with parameters as there are param conversion functions that handle this automatically when you upgrade from older to newer code versions. So long as you don’t use the ‘load params’ button in mission planner after flashing the new firmware.
after letting the drone outside for around 20 minutes I had a 3D fix. I think it’s related to Beitian BN-880. Never had this problem before. Do you know if last position is stored in GPS or and also in ArduPilot config? Could it be the small button battery on GPS?
Being honest, I don’t know alot about gps protocols. I do know that they have what’s called a ‘hot start’ where by they have already been on very recently and it takes less time for them to confirm satalite signals if they have recently been using them. If they have not been used recently then this is refered to as a ‘cold start’. They will take longer to get a good fix. I believe this is handled by the gps unit it’s self though and requires no interaction from ArduPilot.
I have the same gps unit as you and have had to wait on the order of 20 minutes to get a good fix (hdop < 1) if I am in a built up area and on a cold start. In a wide open field and depending on weather etc, that time comes down to more like 5 mins.
As far as I know ArduPilot doesn’t do anything like injecting the last known home position into the gps. I don’t see that this would be a useful feature or good idea (but I don’t know I’m just speculating).
Perhaps, the reason that you are seeing the issue now is because of the fix that went into 4.0. In other words, the version you were flying previously wasn’t correctly determining the health of the gps so it created a false sense of everything working correctly before but in fact the behaviour you see now is the correct one. Again, I am just speculating.
Is this FC the same as Omnibus F4 which you managed to fly with Ardupilot? (My aim is to use Ardupilot on my drone…)
Can you guess which version this FC is by looking on its picture? V5? V6?..
It has GPS in its name… however does it indeed has GPS built-in? Or do I need to buy it separately?
For now I don’t want to buy a transmitter/receiver/goggles but rather use QGroundControl to (a) control the drone and (b) to get video stream from it. My laptop has WiFi and Bluetooth Low Energy. Can I use any/both of them to connect laptop and the drone? Or do I have to purchase some additional hardware for this?
That FC doesn’t have GPS built in you would need to buy a GPS.
I suggest that you buy a transmitter and receiver as you will really struggle to setup a drone without one. You need to be able to fly it in the most basic modes first to enable you to tune it. Some will say that you can fly it via a joystick connected through mission planner but I really don’t recommend this if this is your first drone as just adds more complexity and flying in this way is a lot harder/impossible if the drone is badly tuned. With regard to WiFi, you will need a WiFi telemetry module to be able to connect to the drone via WiFi.
I suggest you go through the wiki on setting up your first drone and follow the instructions to make a simple quadcopter using the recommended/supported hardware: https://ardupilot.org/copter/docs/initial-setup.html
I realize this might not be the right forum for this but there doesn’t seem to be a forum for ArduRover on Omnibus F4 v6. Please direct me to a more appropriate forum if you know of any.
Anyways, I have ArduRover 4.0 on the Omnibus F4 v6 board and everything seems to be working as expected (SBUS, SmartPort telemetry, GPS and compass) but for some reason I can not power both the board and separate ESC from the same battery. I can power the board just fine without the ESC but as soon as the ESC is also connected to battery power, the board shuts down. If I plug the ESC in first and then the battery, the board does not power up at all. If I start all over without the ESC the board powers up again. It makes no difference whether the ESC 5V and signal wire is connected to the PWM/servo pins or not. I have tried with several different ESC:s that I know are working fine.
I have received some help from Lee at Painless360 and he can see nothing apparently wrong with the wiring. Perhaps I have a faulty board…?
I would like to know if anyone has managed to power a separate ESC on this board or are experiencing the same problems that I have?
