Hi, I have a Omnibus F4 Pro V3 flight controller.
I have welded the wires from the battery to the flight controller for the voltage and current measurement (positive and negative), but when I connect the battery the flight controller doesn’t turn on.
When I connect the micro usb cable instead the flight controller turns on and works properly.
It should have a built-in bec or must I use an external bec?
